Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
Firmly pull the battery outwards and away from the laptop.
Remove the seven 6 mm Phillips #0 screws from the back of the case.
Pull upwards on the top of the back cover to remove it.
Pull outwards on the silver metal pins to release the upper RAM module.
Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
Repeat the same process for the lower RAM module.
