Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Loosen the seven 6 mm Phillips #0 screws on the back of the case.
Pull upwards on the top of the back cover to remove it.
Remove the four 9 mm Phillips #0 screws from the cooling assembly.
Gently flip the cooling fan assembly upside-down on the computer surface.
Carefully grab the wire attached to the computer and pull away from the port.
When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
