Inleiding
If your laptop keeps crashing or is running slow, then consider replacing the RAM of your device using this guide here.
Wat je nodig hebt
Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Bijna klaar!
Conclusie
