Ga door naar hoofdinhoud
Gateway Lt4004u Hard Drive Replacement
Wat je nodig hebt
  1. Gateway Lt4004u Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the laptop face down in front of you.
    • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
    • Pinch the switches and slide toward the edges of the computer to unlock.
  2. Gateway Lt4004u Hard Drive Replacement: stap 2, afbeelding 1 van 2 Gateway Lt4004u Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
    • Remove the battery from the laptop.
  3. Gateway Lt4004u Hard Drive Replacement, Keyboard: stap 3, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement, Keyboard: stap 3, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Open the laptop so that the screen and keyboard are facing you.
    • Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
  4. Gateway Lt4004u Hard Drive Replacement: stap 4, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement: stap 4, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Use an opening pick to push each tab away from you.
    • Use an opening tool to push the middle tab until you hear a click. Begin to push the tool downward into the computer and slide the card along the length of the keyboard, as you overcome the five tabs.
    • A clicking sound is normal and no cause for alarm.
  5. Gateway Lt4004u Hard Drive Replacement: stap 5, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement: stap 5, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
    • Carefully pry the keyboard from the main frame, starting at the top section.
    • Look at the intel sticker in this step and the next to orient your computer with the pictures.
  6. Gateway Lt4004u Hard Drive Replacement: stap 6, afbeelding 1 van 2 Gateway Lt4004u Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Look at the intel sticker in this step and the previous step to orient your computer with the pictures.
    • Unplug the thin blue connection piece beneath the keyboard. It may pop off on its own while you are prying off the keyboard.
    • The popping noise will not hurt the computer.
    • Once the thin blue plastic has been detached, remove the keyboard from the rest of the laptop.
  7. Gateway Lt4004u Hard Drive Replacement, Back Panel: stap 7, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement, Back Panel: stap 7, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement, Back Panel: stap 7, afbeelding 3 van 3
    • Locate and unscrew the five screws indicated by the red circles in the picture using a Phillip's #0 screwdriver. All of the screws are 8.0 mm, excluding the top right screw which is shorter. It should be 5.0mm.
    • Each screw should have the word "DOOR" engraved beside or above it.
  8. Gateway Lt4004u Hard Drive Replacement: stap 8, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement: stap 8, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • Hold the computer in your hands and use the tip of your screwdriver or a spudger to push through the bottom right hand hole left by the removed screw. This hole is shown in the picture within a red box.
    • The tip of the screwdriver will push against the bottom casing of the laptop and pop it away from the rest of the frame.
    • There will be a loud cracking noise as the bottom of the computer detaches. You are not breaking it!
  9. Gateway Lt4004u Hard Drive Replacement: stap 9, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement: stap 9, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement: stap 9, afbeelding 3 van 3
    • Close the laptop and place it in front of you face-down with the hinge connecting the screen and keyboard away from you on the table. Pry the rest of the bottom casing away from the computer, exposing the inside.
    • Note that the laptop in this picture has both been placed upside down and rotated 180 degrees from the previous picture.
  10. Gateway Lt4004u Hard Drive Replacement, Hard Drive: stap 10, afbeelding 1 van 3 Gateway Lt4004u Hard Drive Replacement, Hard Drive: stap 10, afbeelding 2 van 3 Gateway Lt4004u Hard Drive Replacement, Hard Drive: stap 10, afbeelding 3 van 3
    • Locate the hard drive in the top left hand corner of the device. It is a teal blue-green color with the top right corner covered by a black piece of plastic.
    • Gently insert your fingernail or a spudger into the crevice on the right side of the hard drive in order to pry the hard drive from the bottom of the laptop.
    • Note that the laptop has been rotated 180 degrees from the first picture of this step to the second picture. The hard drive is shown in the top left corner in the first picture, but in the bottom right corner in the second.
  11. Gateway Lt4004u Hard Drive Replacement: stap 11, afbeelding 1 van 2 Gateway Lt4004u Hard Drive Replacement: stap 11, afbeelding 2 van 2
    • Use your fingers to unplug the black plastic connection from the left side of the hard drive.
    • Remove the hard drive from the rest of the laptop.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Carlisle Hiott
812 Reputatie
7 handleidingen geschreven
Clemson, Team 6-5, Benson Spring 2016 Lid van Clemson, Team 6-5, Benson Spring 2016
CLEM-BENSON-S16S6G5
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 2,470
