Ga door naar hoofdinhoud
Gateway LT41P10u Cooling Fan Replacement
Wat je nodig hebt
  1. Gateway LT41P10u Cooling Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  4. Gateway LT41P10u Cooling Fan Replacement, Keyboard: stap 4, afbeelding 1 van 2 Gateway LT41P10u Cooling Fan Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Once the battery is removed, flip the laptop over and open it up so you can see the keyboard.
    • Underneath the f4, f8, and f12 keys there are indents (see the second image) to fit a spudger or plastic opening tool to pop the keyboard off.
    • Once you find an indent with your spudger, carefully move it so the top of the keyboard comes away from the rest of the computer, followed by the bottom of the keyboard.
  5. Gateway LT41P10u Cooling Fan Replacement: stap 5, afbeelding 1 van 1
    • Once you pull the keyboard off, you will see a ribbon wire connecting the keyboard to the rest of the laptop.
    • To detach the keyboard from the rest of the computer, you have to unlock the ribbon by pulling up on the small black lock keeping the ribbon from being removed. You won't have to pull very hard, so be gentle to avoid damaging it.
    • Once the ribbon is disconnected from the computer, you are able to pull the ribbon out from underneath the lock, and then pull the keyboard away.
  6. Gateway LT41P10u Cooling Fan Replacement, Track Pad: stap 6, afbeelding 1 van 3 Gateway LT41P10u Cooling Fan Replacement, Track Pad: stap 6, afbeelding 2 van 3 Gateway LT41P10u Cooling Fan Replacement, Track Pad: stap 6, afbeelding 3 van 3
    • Remove screws from back plate using phillips screwdriver.
    • After removing the back screws use same phillips screwdriver to remove all screws from top plate. (see images 2 and 3, bottom screws from image 2 overlap with top screws from image 3.)
    • Once all screws are removed from top and bottom plates disconnect cable ribbon indicated by a red arrow in images 2 and 3.
  7. Gateway LT41P10u Cooling Fan Replacement: stap 7, afbeelding 1 van 2 Gateway LT41P10u Cooling Fan Replacement: stap 7, afbeelding 2 van 2
    • Carefully remove plate.
    • Track pad is located on the under side of the plate indicated by image 2.
    • To replace track pad you must replace the entire plate. (Track pad is permanently attached this plate.)
  8. Gateway LT41P10u Cooling Fan Replacement, Cooling Fan: stap 8, afbeelding 1 van 2 Gateway LT41P10u Cooling Fan Replacement, Cooling Fan: stap 8, afbeelding 2 van 2
    • By hand, remove the top left tape in order to free the tab underneath.
    • Remove the two small tabs at the bottom middle of the laptop and the whole board will be free.
    • The board may now be removed from the laptop
  9. Gateway LT41P10u Cooling Fan Replacement: stap 9, afbeelding 1 van 2 Gateway LT41P10u Cooling Fan Replacement: stap 9, afbeelding 2 van 2
    • Remove the wiring connector by hand or with the help of a flathead screwdriver if necessary.
    • Remove both screws with a philips head screwdriver.
    • The cooling fan is now completely removed and may be replaced with new parts.
Conclusie
Patrick Raposo
201 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Lid van UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 258
