Inleiding
This is a moderately difficult process. The screen is an essential part of the computer and it is important to follow these steps with care to prevent unwanted damages to the device.
Wat je nodig hebt
Open the laptop so that the screen and keyboard are facing you.
Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
Remove the screen casing.
Één andere persoon heeft deze handleiding voltooid.
