Inleiding
This guide will walk you through the process of replacing a dead or dying battery in a Gateway LT2514u.
Wat je nodig hebt
With the netbook's lid closed, flip it over and slide the latch on the upper left hand side of the netbook to the left.
If the release switch in the upper right-hand area is missing, insert a slender tool (we used tweezers) into the left side of the smaller hole.
Slide and hold the tweezers to the right and use your other hand to slide the battery out.
Één andere persoon heeft deze handleiding voltooid.
