Inleiding
This guide will show the steps required to remove a broken speaker from the netbook, and replace it with a new speaker.
Onderdelen
Geen onderdelen nodig.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Voeg opmerking toe
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Voeg opmerking toe
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Voeg opmerking toe
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Voeg opmerking toe
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Voeg opmerking toe
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Voeg opmerking toe
  • Remove the 5mm screw of the left speaker cover using a Phillips #0 screwdriver, as shown here.
Voeg opmerking toe
  • Disconnect the speaker's connection to the motherboard by lightly pulling on the connector until it pops apart from the motherboard.
Voeg opmerking toe
  • Repeat the previous steps for the right speaker. Remove the 5mm screw of the right speaker cover using a Phillips #0 screwdriver.
Voeg opmerking toe
Voeg opmerking toe
Voeg opmerking toe
Conclusie
Emily
301 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 82
