Onderdelen
Geen onderdelen nodig.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Voeg opmerking toe
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Voeg opmerking toe
The RAM is located under this cover.
  • The RAM is located under this cover.
Voeg opmerking toe
Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
  • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
  • Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
Voeg opmerking toe
Unlock the RAM by pinching the metal clamps that keep the RAM in place. Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
  • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
  • Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
Voeg opmerking toe
Conclusie
Emily
301 reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 101
