Inleiding
LCD (liquid crystal display) is another term to use for display in computer or technology device. LCD is need to replace if the screen was not on or if it is damage by any other factor like water, crack by contacting to the hard surface.
LCD damage can make a laptop unusable, so it is necessary to replace it as soon you could.
Onderdelen
Geen onderdelen nodig.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Voeg opmerking toe
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Voeg opmerking toe
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Voeg opmerking toe
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Voeg opmerking toe
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Voeg opmerking toe
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Voeg opmerking toe
  • Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
  • Be careful not to damage the computer screen in the process.
Voeg opmerking toe
  • Separate the monitor from the border cover once all snap connections have been pried apart.
Voeg opmerking toe
  • Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
Voeg opmerking toe
  • Take the screen out of the top cover.
Voeg opmerking toe
Conclusie
My Linh Pham
301 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 184
