Inleiding
This is a guide on how to remove the hard drive on this lap top. Reasons for removal of the hard drive are the current one has stopped working, or to get upgrade to a more improved hard drive.
Onderdelen
Geen onderdelen nodig.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Voeg opmerking toe
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Voeg opmerking toe
The hard drive is located on the bottom of the laptop on the left hand side.
  • The hard drive is located on the bottom of the laptop on the left hand side.
Voeg opmerking toe
Remove the two scores on the cover with the screwdriver specified.
  • Remove the two scores on the cover with the screwdriver specified.
Voeg opmerking toe
Lift off the cover with the plastic opener.
  • Lift off the cover with the plastic opener.
Voeg opmerking toe
Unscrew the one screw holding the hard drive in place with the same screw driver.
  • Unscrew the one screw holding the hard drive in place with the same screw driver.
Voeg opmerking toe
Slide the hard drive up and remove it from the laptop.
  • Slide the hard drive up and remove it from the laptop.
Voeg opmerking toe
Conclusie
Kyle
622 Reputatie
10 handleidingen geschreven
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 243
