Inleiding
This is a repair guide on how to remove the cooling fan. Reasons to replace this part are it is making a lot of noise, it is damaged, it may have melted fem overuse of the lap top, or the software the computer is running is too powerful.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Voeg opmerking toe
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Voeg opmerking toe
Remove all 11 of the screw shown on the bottom of the lap top using the specified screw driver. Remove all 11 of the screw shown on the bottom of the lap top using the specified screw driver.
  • Remove all 11 of the screw shown on the bottom of the lap top using the specified screw driver.
Voeg opmerking toe
Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out. Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out. Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out.
  • Lift off the keyboard by doing exactly what is shown in the first picture. Get the head of the plastic opening tool under and then wedge it out.
Voeg opmerking toe
Remove the 5 circled screws with the Phillips #0 screw driver. Carefully separate the back cover from the front either using your hands or a plastic opening tool. Carefully separate the back cover from the front either using your hands or a plastic opening tool.
  • Remove the 5 circled screws with the Phillips #0 screw driver.
  • Carefully separate the back cover from the front either using your hands or a plastic opening tool.
Voeg opmerking toe
Unscrew this 1 screw to remove the wifi card. Then unplug the wires it is attached to and take it out.
  • Unscrew this 1 screw to remove the wifi card.
  • Then unplug the wires it is attached to and take it out.
Voeg opmerking toe
Use the phillps #00 screw driver to remove these 3 small scows so the motherboard can be removed. Then remove it from the base of th computer.
  • Use the phillps #00 screw driver to remove these 3 small scows so the motherboard can be removed.
  • Then remove it from the base of th computer.
Voeg opmerking toe
Use the Phillips #00 screw driver to remove the 4 circled screws.
  • Use the Phillips #00 screw driver to remove the 4 circled screws.
Voeg opmerking toe
Disconnect the wires from the motherboard.
  • Disconnect the wires from the motherboard.
  • The fan should now be fully disconnected and ready to replace.
Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyle
622 reputatie
10 handleidingen geschreven
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 145
