Inleiding
If you have a Phillips #0 screwdriver, you can easily replace the 3G card.
Onderdelen
Geen onderdelen nodig.
Unlock the tab located in the top left corner of the netbook. The red tab indicated that the battery has been properly unlocked. Remove the battery.
  • Unlock the tab located in the top left corner of the netbook.
  • The red tab indicated that the battery has been properly unlocked.
  • Remove the battery.
  • When working with electronics, it is always wise to remove the power source before taking the device apart.
Voeg opmerking toe
The 3G card is located under this cover.
  • The 3G card is located under this cover.
Voeg opmerking toe
Use the Phillips #0 screwdriver to remove one (1) 5mm screw. Use the plastic opening tools to lift up the cover. Use the plastic opening tools to lift up the cover.
  • Use the Phillips #0 screwdriver to remove one (1) 5mm screw.
  • Use the plastic opening tools to lift up the cover.
Voeg opmerking toe
Using the Phillips #0 screwdriver, remove one (1) 5mm screw holding the card in place.
  • Using the Phillips #0 screwdriver, remove one (1) 5mm screw holding the card in place.
Voeg opmerking toe
Remove the 3G card from the computer by lifting the card up from the bottom.
  • Remove the 3G card from the computer by lifting the card up from the bottom.
Voeg opmerking toe
Notice the two wires connected to the card. Gently detach the wires from the card. The metal portions will "pop" off
  • Notice the two wires connected to the card.
  • Gently detach the wires from the card. The metal portions will "pop" off
Voeg opmerking toe
Conclusie
Lydia Benjock
1.189 Reputatie
22 handleidingen geschreven
Clemson, Team 14-3, Benson Fall 2013 Lid van Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Leden
24 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 482
