Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Remove the battery cover using the tab on the right side.
Take the battery out with your index finger.
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Follow the black ribbon cable to the connector and gently pull straight up.
Remove the five screws with a Phillips #0 screwdriver.
Lift the hinge covers along the outer edges with the spudger until they are released.
Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
Remove the cable by gently pulling it out while holding down the LCD.
Slide the release and push the button to eject the drive.
Remove the drive.
Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
Lift the plug holding the mouse ribbon about 1/16 inch or until it stops
Remove the ribbon.
Insert your spudger between the upper and lower case at the drive bay closest to the battery.
Carefully and slowly go around the entire case, unseating all plastic clips holding the upper and lower cases together.
Lift the upper case about 1/4 inch.
At the rear of the case is one last connecting wire. Unplug it and remove the upper case.
Één andere persoon heeft deze handleiding voltooid.
