Ga door naar hoofdinhoud
Gateway 600YG2 LCD Replacement
Wat je nodig hebt
  1. Gateway 600YG2 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over. Slide the battery release tap to the right with your index finger.
  2. Gateway 600YG2 LCD Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery cover and the battery out with your index finger.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: stap 3, afbeelding 1 van 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Lift the power button panel gently located above the F12 key. Beginning with the right to the left, using a spudger (optional).
  4. Gateway 600YG2 LCD Replacement, LCD: stap 4, afbeelding 1 van 1
    • Take out and remove 5 screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they become released.
  5. Gateway 600YG2 LCD Replacement: stap 5, afbeelding 1 van 1
    • Unplug the LCD from the system board gently.
  6. Gateway 600YG2 LCD Replacement: stap 6, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove 6 screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: stap 7, afbeelding 1 van 1
    • Double-check any cables connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
Conclusie
Elizabeth Mazer
78 Reputatie
10 handleidingen geschreven
Cal Poly, Team 20-10, Maness Fall 2010 Lid van Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Leden
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,847
