Ga door naar hoofdinhoud
Inleiding
Removal of LCD display
Onderdelen
Geen onderdelen opgegeven.
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
  3. Insert the spudger between the "sysrq" and "ins" keys.
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently lift the power button panel from the right to left.
  4. Remove 5 screws.
    • Remove 5 screws.
    • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
    • Remove hinge covers.
  5. Gently unplug LCD from system board.
    • Gently unplug LCD from system board.
  6. Remove 6 screws holding LCD to hinge.
    • Remove 6 screws holding LCD to hinge.
  7. Pull LCD away from case.
    • Pull LCD away from case.
Conclusie
Elizabeth Mazer
78 Reputatie
10 handleidingen geschreven
Cal Poly, Team 20-10, Maness Fall 2010 Lid van Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Leden
22 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,748
