Ga door naar hoofdinhoud
Gateway 600YG2 Keyboard Replacement
Wat je nodig hebt
  1. Gateway 600YG2 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over.
    • Slide the battery release tab to the right to open the battery cover.
  2. Gateway 600YG2 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover using the tab on the right side.
    • Lift and remove the battery.
  3. Gateway 600YG2 Keyboard Replacement, Power Button Panel: stap 3, afbeelding 1 van 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
  4. Gateway 600YG2 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove the five screws holding the keyboard in place.
  5. Gateway 600YG2 Keyboard Replacement: stap 5, afbeelding 1 van 2 Gateway 600YG2 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Possible device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Possible device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable and gently pull straight up.
Conclusie
Elizabeth Mazer
78 Reputatie
10 handleidingen geschreven
Cal Poly, Team 20-10, Maness Fall 2010 Lid van Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 63
Altijd: 1,650
