Ga door naar hoofdinhoud
Gateway 3545GZ Fan Replacement
Wat je nodig hebt
  1. Gateway 3545GZ Fan Replacement, Fan: stap 1, afbeelding 1 van 2 Gateway 3545GZ Fan Replacement, Fan: stap 1, afbeelding 2 van 2
    • Unscrew 14mm screws with Phillips screwdriver.
    • Unscrew 3mm screws with the same Phillips screwdriver.
    • Screws that are circled in red are 3mm; the screw circled in blue is 14mm
    • Remove the protective cover.
  2. Gateway 3545GZ Fan Replacement: stap 2, afbeelding 1 van 3 Gateway 3545GZ Fan Replacement: stap 2, afbeelding 2 van 3 Gateway 3545GZ Fan Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the four screws holding it in place with the same PH1 Phillips-Head screwdriver. They are numbered on the fan, 1,2,3,4.
    • The four screws are 12mm long, they also have a spring surrounding them.
    • Then carefully pull the cord connecting the fan to the notebook.
    • Insert your replacement fan, plug in its cord, screw it into place, and reattach the protective cover.
Conclusie
Nathan Parr
25 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 204
