Ga door naar hoofdinhoud
Garmin nuviCam LMTHD Motherboard Replacement
Wat je nodig hebt
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: stap 1, afbeelding 1 van 2 Garmin nuviCam LMTHD Motherboard Replacement, Screen: stap 1, afbeelding 2 van 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: stap 2, afbeelding 1 van 2 Garmin nuviCam LMTHD Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: stap 4, afbeelding 1 van 2 Garmin nuviCam LMTHD Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: stap 10, afbeelding 1 van 2 Garmin nuviCam LMTHD Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: stap 11, afbeelding 1 van 2 Garmin nuviCam LMTHD Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Lift motherboard out of device using plastic opening tools.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 22
Altijd: 617
