Ga door naar hoofdinhoud
Garmin nuviCam LMTHD Battery Replacement
Wat je nodig hebt
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: stap 1, afbeelding 1 van 2 Garmin nuviCam LMTHD Battery Replacement, Screen: stap 1, afbeelding 2 van 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Battery Replacement: stap 2, afbeelding 1 van 2 Garmin nuviCam LMTHD Battery Replacement: stap 2, afbeelding 2 van 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Battery Replacement: stap 4, afbeelding 1 van 2 Garmin nuviCam LMTHD Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: stap 6, afbeelding 1 van 1
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: stap 8, afbeelding 1 van 1
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
Conclusie
7 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Where did you buy the battery? What is the voltage/current?
John Justin - Antwoord
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
Gary - Antwoord
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
guy.adamson - Antwoord
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
Zach - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 4,945
