Ga door naar hoofdinhoud
  1. Locate the four screws in the four corners of the back panel.
    • Locate the four screws in the four corners of the back panel.
  2. Using a T5 Torx Screwdriver, begin unscrewing the  four 11.0 mm  screws from the back panel.
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  3. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  4. Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  5. Lift the beige clamp using a tweezer or your fingernail and remove the connector.
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  6. Lift the connector gently from the socket.
    • Lift the connector gently from the socket.
  7. Pop out the panel along the edges and remove it from the border.
    • Pop out the panel along the edges and remove it from the border.
Conclusie
Ricardo Audain
551 Reputatie
5 handleidingen geschreven
USF Tampa, Team 6-4, Remmell Fall 2016 Lid van USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 265
