Ga door naar hoofdinhoud
  1. Locate the four screws in the four corners of the back panel.
    • Locate the four screws in the four corners of the back panel.
  2. Using a T5 Torx Screwdriver, begin unscrewing the  four 11.0 mm  screws from the back panel.
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  3. Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  4. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  5. Lift the beige clamp using a tweezer or your fingernail and remove the connector.
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  6. Lift the connector gently from the socket.
    • Lift the connector gently from the socket.
  7. Using a pair of tweezers, grab the connecting wires and lift the terminal from the motherboard.
    • Using a pair of tweezers, grab the connecting wires and lift the terminal from the motherboard.
    • Avoid contacting battery terminals with metallic objects.
  8. Pry the battery out of the back cover using a plastic opening tool.
    • Pry the battery out of the back cover using a plastic opening tool.
    • Work the edges and apply force when removing the battery, as it will be glued down.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ricardo Audain
551 Reputatie
5 handleidingen geschreven
USF Tampa, Team 6-4, Remmell Fall 2016 Lid van USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
4 Leden
Can someone give me the close picture of motherboard area near usb charger. I have problems with charging device. I think one chip burned.
Thanks
Marko Vodenik - Antwoord
The T10 Torx screwdriver mentioned in this article and sold by IFixit (product number IF 145-080-4) is too big and does not fit the much smaller screws on the Garmin 2460. I wasted around £10 on a screwdriver that does not do the job!
Julian Renselar - Antwoord
1. Mine cover screws take a Torx T5. Bought a kit with all sizes (plus some other handy tiny electronic tools)on Amazon for $6.00 US.
2. The twisted wires from the back cover to the circuit board may not have a connector. The wire in mine was secured to the circuit board with two molecule-sized spots of solder which, of course, broke loose as soon as I opened the cover, stretching the too-short wire to its limit. I don’t know the funtion of this pair of small, twisted wires. They go from the circuit board to a slit opening in the back cover. Maybe a microphone for the bluetooth?? With no way to re-solder the two barely visible spots, I taped the wire out of the way and closed the unit back up. GPS functions all still work. Haven’t tried the bluetooth…I don’t use it anyway.
Michael - Antwoord
Sounds easy until you try to reconnect the tape connector to the motherboard. You need the eyes of an eagle, the luck of the Irish, and the patience of Job to remake that connection.
Ed Selby - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 84
Altijd: 2,654
