Ga door naar hoofdinhoud
Garmin fenix 6X Sapphire Motherboard Replacement
Wat je nodig hebt
  1. Garmin fenix 6X Sapphire Motherboard Replacement, Display: stap 1, afbeelding 1 van 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Motherboard Replacement: stap 2, afbeelding 1 van 2 Garmin fenix 6X Sapphire Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
  3. Garmin fenix 6X Sapphire Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Remove the four 5mm silver screws on the outer part of the motherboard using the T5 Torx screwdriver.
    • Pull the motherboard out carefully as it is connected on the other side by another ribbon connector.
  4. Garmin fenix 6X Sapphire Motherboard Replacement: stap 4, afbeelding 1 van 3 Garmin fenix 6X Sapphire Motherboard Replacement: stap 4, afbeelding 2 van 3 Garmin fenix 6X Sapphire Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Unlock the ZIF connector and remove the ribbon connector from the back of the motherboard.
    • A Jimmy can be used if you have trouble prying the piece with your fingers.
    • Be careful not to pull on the ribbon as it could tear.
    • Remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
matthew long
522 Reputatie
5 handleidingen geschreven
Clemson, Team 1-5, Hunter Spring 2022 Lid van Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Leden
8 handleidingen geschreven
2 opmerkingen
Where can we buy a garmin fenix motherboard?
Olivier Schmidt - Antwoord
I have a tactix delta I want to repair a button on (middle left side, as the button is shattered internally), and it feels next to impossible trying to find replacement parts. for as easy as it is to disassemble, you'd think it would be easy to source parts... but no... and the only way to get it fixed via Garmin is to trade it in for $150, and you'll receive a different refurbished one!!! so disappointing. it almost feels like I wasted $1000.
Sean Miller -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 93
Altijd: 2,283
