Ga door naar hoofdinhoud
Garmin fenix 6X Sapphire Display Replacement
Wat je nodig hebt
  1. Garmin fenix 6X Sapphire Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Display Replacement: stap 2, afbeelding 1 van 2 Garmin fenix 6X Sapphire Display Replacement: stap 2, afbeelding 2 van 2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
Conclusie
5 andere personen hebben deze handleiding voltooid.
matthew long
522 Reputatie
5 handleidingen geschreven
Clemson, Team 1-5, Hunter Spring 2022 Lid van Clemson, Team 1-5, Hunter Spring 2022
CLEM-HUNTER-S22S1G5
4 Leden
8 handleidingen geschreven
2 opmerkingen
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - Antwoord
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 175
Altijd: 7,252
