Inleiding
These instructions will teach you how to replace your LCD screen.
Wat je nodig hebt
Flip the device to the backside, and locate the metal tab at the center of the back cover.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
Gently pull the wire ribbon from the white connector.
It is easy to pull the ribbon cable off, but reinserting the ribbon cable back into the wire connector is very challenging. Any tips?
After removing the motherboard, locate the two #1 Philips screws.
Carefully remove both screws.
Insert the new LCD screen in the device.
Hi, I was wondering where I could get one new screen for my garmin etrex legend HCx.
Thank you very much,
Jordi
Hi there…Could you please help…Looking for a replacement LCD screen for a Garmin Venture Etrex? Kind regards….
leon.visagie75@gmail.com
3 andere personen hebben deze handleiding voltooid.
