Inleiding
These instructions will teach you how to replace your LCD screen.
Wat je nodig hebt
Flip the device to the backside, and locate the metal tab at the center of the back cover.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
After removing the motherboard, locate the two #1 Philips screws.
Carefully remove both screws.
3 andere personen hebben deze handleiding voltooid.
