Ga door naar hoofdinhoud
Garmin eTrex Vista H LCD screen Replacement
Wat je nodig hebt
  1. Garmin eTrex Vista H LCD screen Replacement, Removing Battery: stap 1, afbeelding 1 van 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H LCD screen Replacement: stap 2, afbeelding 1 van 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H LCD screen Replacement: stap 3, afbeelding 1 van 2 Garmin eTrex Vista H LCD screen Replacement: stap 3, afbeelding 2 van 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: stap 4, afbeelding 1 van 2 Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: stap 4, afbeelding 2 van 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H LCD screen Replacement: stap 5, afbeelding 1 van 3 Garmin eTrex Vista H LCD screen Replacement: stap 5, afbeelding 2 van 3 Garmin eTrex Vista H LCD screen Replacement: stap 5, afbeelding 3 van 3
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H LCD screen Replacement: stap 6, afbeelding 1 van 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H LCD screen Replacement: stap 7, afbeelding 1 van 2 Garmin eTrex Vista H LCD screen Replacement: stap 7, afbeelding 2 van 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H LCD screen Replacement, Disassembling Garmin eTrex Vista H Motherboard: stap 8, afbeelding 1 van 1
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H LCD screen Replacement: stap 9, afbeelding 1 van 1
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H LCD screen Replacement: stap 10, afbeelding 1 van 2 Garmin eTrex Vista H LCD screen Replacement: stap 10, afbeelding 2 van 2
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
  11. Garmin eTrex Vista H LCD screen Replacement, LCD screen: stap 11, afbeelding 1 van 3 Garmin eTrex Vista H LCD screen Replacement, LCD screen: stap 11, afbeelding 2 van 3 Garmin eTrex Vista H LCD screen Replacement, LCD screen: stap 11, afbeelding 3 van 3
    • After removing the motherboard, locate the two #1 Philips screws.
    • Carefully remove both screws.
  12. Garmin eTrex Vista H LCD screen Replacement: stap 12, afbeelding 1 van 2 Garmin eTrex Vista H LCD screen Replacement: stap 12, afbeelding 2 van 2
    • Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
    • Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
  13. Garmin eTrex Vista H LCD screen Replacement: stap 13, afbeelding 1 van 1
    • Insert the new LCD screen in the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Lauren Noyes
248 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-30, Regan Fall 2010 Lid van Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Leden
5 handleidingen geschreven
Één opmerking
where can I find the LCD test
carlos gomes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 11,886
