Ga door naar hoofdinhoud
Garmin Vivoactive HR Display Replacement
Wat je nodig hebt
  1. Garmin Vivoactive HR Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: stap 2, afbeelding 1 van 1
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
  3. Garmin Vivoactive HR Display Replacement: stap 3, afbeelding 1 van 1
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: stap 4, afbeelding 1 van 2 Garmin Vivoactive HR Display Replacement: stap 4, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Chris Corry
256 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G5, Harley Summer 2018 Lid van IUPUI, Team S2-G5, Harley Summer 2018
IUPUI-HARLEY-SU18S2G5
3 Leden
3 handleidingen geschreven
19 opmerkingen
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - Antwoord
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - Antwoord
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - Antwoord
What type of glue i use to connect the display an the body?
culibrkboj - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 105
Altijd: 25,760
