Ga door naar hoofdinhoud
Garmin Nuvi 65LM Speaker Replacement
Wat je nodig hebt
  1. Garmin Nuvi 65LM Speaker Replacement, Plastic device casing: stap 1, afbeelding 1 van 2 Garmin Nuvi 65LM Speaker Replacement, Plastic device casing: stap 1, afbeelding 2 van 2
    • Place the device on a flat surface with the screen facing down.
    • Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
  2. Garmin Nuvi 65LM Speaker Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 65LM Speaker Replacement: stap 2, afbeelding 2 van 2
    • There is a ribbon cable that will still connect the front and back panels once they are pried part.
    • Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
    • Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
  3. Garmin Nuvi 65LM Speaker Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 65LM Speaker Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 65LM Speaker Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to pop up the ZIF connector tab that fastens the ribbon cable to the motherboard.
    • Gently pull the front panel away and set it on your flat work surface.
  4. Garmin Nuvi 65LM Speaker Replacement, Speaker: stap 4, afbeelding 1 van 3 Garmin Nuvi 65LM Speaker Replacement, Speaker: stap 4, afbeelding 2 van 3 Garmin Nuvi 65LM Speaker Replacement, Speaker: stap 4, afbeelding 3 van 3
    • This step requires soldering. If you are new to soldering reference the Soldering Section of Ifixit's Device Skills Page for helpful information on soldering prior to attempting this step.
    • Disconnect the black and blue speaker wires by desoldering them from the terminals on the motherboard.
    • Plug in the soldering station and allow it at least 5 minutes to heat up.
    • Careful, the soldering iron and molten solder are very hot and can burn you!
    • Touch the tip of the soldering iron to each terminal until the solder begins to melt.
    • Once the solder melts gently pull the wire away from its connection to the terminal.
  5. Garmin Nuvi 65LM Speaker Replacement: stap 5, afbeelding 1 van 3 Garmin Nuvi 65LM Speaker Replacement: stap 5, afbeelding 2 van 3 Garmin Nuvi 65LM Speaker Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool between the speaker and plastic case.
    • Gently pry the speaker up until you make a gap between the speaker and plastic case.
    • Continue to do this while moving the plastic opening tool around the entire circumference of the speaker.
    • Use your fingers to gently pull the speaker completely away from the plastic case.
Conclusie
To reassemble your device, apply glue to the outer rim of the new speaker and secure it to the plastic case. Then follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Alex King
255 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-3, Amido Spring 2015 Lid van Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Leden
6 handleidingen geschreven
2 opmerkingen
great info…any ideas on where to get the new speaker???
dpdsergeant1 - Antwoord
I have the same question…
Robert Scire Risichella -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 459
