Inleiding
This guide provides a quick and simple fix to one of the most common problems concerning this device. Before continuing it should be noted that this battery is a lithium ion battery. Any puncturing to the outer shell of the battery could risk a corrosive hazard as well as releasing flammable vapors.
Wat je nodig hebt
There are four 11.0 mm screws located at each corner on the back of the device.
With the T5 torx screwdriver, remove these screws and set aside in a safe place.
