Ga door naar hoofdinhoud
Garmin Nuvi 56LMT Battery Replacement
Wat je nodig hebt
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Garmin Nuvi 56LMT Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: stap 2, afbeelding 1 van 3 Garmin Nuvi 56LMT Battery Replacement: stap 2, afbeelding 2 van 3 Garmin Nuvi 56LMT Battery Replacement: stap 2, afbeelding 3 van 3
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 56LMT Battery Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 56LMT Battery Replacement: stap 3, afbeelding 3 van 3
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: stap 4, afbeelding 1 van 3 Garmin Nuvi 56LMT Battery Replacement: stap 4, afbeelding 2 van 3 Garmin Nuvi 56LMT Battery Replacement: stap 4, afbeelding 3 van 3
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: stap 5, afbeelding 1 van 1
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Conclusie
Christopher Keller
102 Reputatie
1 Handleiding geschreven
USF Tampa, Team S3-G5, Nance Fall 2017 Lid van USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 416
