Ga door naar hoofdinhoud
Garmin Nuvi 50LM Power Button Replacement
Wat je nodig hebt
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: stap 1, afbeelding 1 van 2 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: stap 1, afbeelding 2 van 2
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 50LM Power Button Replacement: stap 2, afbeelding 2 van 2
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: stap 3, afbeelding 1 van 2 Garmin Nuvi 50LM Power Button Replacement: stap 3, afbeelding 2 van 2
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
Conclusie
Maurice Thomas
661 Reputatie
5 handleidingen geschreven
3 opmerkingen
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - Antwoord
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - Antwoord
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 31
Altijd: 6,803
