Ga door naar hoofdinhoud
Garmin Nuvi 2797LMT LCD Screen Replacement
Wat je nodig hebt
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: stap 2, afbeelding 1 van 3 Garmin Nuvi 2797LMT LCD Screen Replacement: stap 2, afbeelding 2 van 3 Garmin Nuvi 2797LMT LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: stap 5, afbeelding 1 van 2 Garmin Nuvi 2797LMT LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: stap 6, afbeelding 1 van 2 Garmin Nuvi 2797LMT LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
Conclusie
4 andere personen hebben deze handleiding voltooid.
baileykaytar
366 Reputatie
2 handleidingen geschreven
2 opmerkingen
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - Antwoord
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 2,313
