Ga door naar hoofdinhoud
Garmin Nuvi 265WT Screen Replacement
Wat je nodig hebt
  1. Garmin Nuvi 265WT Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Remove PN/Model sticker an the lower side of the device.
    • Use pentalobe screwdriver to remove the two screws underneath it.
    • Use the nylon spudger to remove the screen from the device.
    • The regular black nylon spudger should be used whenever possible, especially around glass displays and other sensitive components.
  2. Garmin Nuvi 265WT Screen Replacement: stap 2, afbeelding 1 van 1
    • Lift up the screen gently and place it on the opposite side.
  3. Garmin Nuvi 265WT Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
  4. Garmin Nuvi 265WT Screen Replacement: stap 4, afbeelding 1 van 1
    • Lift up the screen and you're done.
Conclusie
Patricia Gonzalez
337 Reputatie
3 handleidingen geschreven
Texas Tech, Team 6-4, Bennett Fall 2016 Lid van Texas Tech, Team 6-4, Bennett Fall 2016
TTU-BENNETT-F16S6G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 447
