Ga door naar hoofdinhoud
Garmin Nuvi 2595LMT LCD Screen Replacement
Wat je nodig hebt
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: stap 1, afbeelding 1 van 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 2595LMT LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 2595LMT LCD Screen Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 2595LMT LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 2 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: stap 4, afbeelding 2 van 2
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: stap 5, afbeelding 1 van 2 Garmin Nuvi 2595LMT LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Place new screen in proper position, with the ribbon facing downward.
Conclusie
3 opmerkingen
cannot prise open the connector to replace ribbon
norman bayne - Antwoord
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - Antwoord
Re-seating the ribbon is simply impossible.
daBee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 4,626
