Ga door naar hoofdinhoud
Garmin Nuvi 255W Battery Replacement
Wat je nodig hebt
  1. Garmin Nuvi 255W Battery Replacement, Power Button: stap 1, afbeelding 1 van 1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Battery Replacement: stap 3, afbeelding 1 van 2 Garmin Nuvi 255W Battery Replacement: stap 3, afbeelding 2 van 2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Battery Replacement: stap 4, afbeelding 1 van 2 Garmin Nuvi 255W Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the power button.
  5. Garmin Nuvi 255W Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Battery Replacement: stap 6, afbeelding 1 van 2 Garmin Nuvi 255W Battery Replacement: stap 6, afbeelding 2 van 2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Battery Replacement: stap 7, afbeelding 1 van 2 Garmin Nuvi 255W Battery Replacement: stap 7, afbeelding 2 van 2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Timothy
73 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-3, Regan Winter 2012 Lid van Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Leden
4 handleidingen geschreven
9 opmerkingen
Thanks for this very nicely illustrated guide.
RBStorms - Antwoord
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - Antwoord
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - Antwoord
Thanks, great demonstration.
peter2x4 - Antwoord
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 62
Altijd: 26,665
