Ga door naar hoofdinhoud
Garmin Nuvi 2557LMT Screen Replacement
Wat je nodig hebt
  1. Garmin Nuvi 2557LMT Screen Replacement, Garmin Nuvi 2557LMT Disassembly: stap 1, afbeelding 1 van 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Screen Replacement: stap 2, afbeelding 1 van 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Screen Replacement: stap 3, afbeelding 1 van 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Screen Replacement: stap 4, afbeelding 1 van 2 Garmin Nuvi 2557LMT Screen Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • With the screen facing down, firmly grip the sides of the screen frame and pop the screen out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 457
