Inleiding
The tools needed are T5 Torx Screwdriver, plastic opening tool, and a soldering iron. In order to take out the motherboard you will need to disconnect the battery and the speaker from it also.
Wat je nodig hebt
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Using a T5 Torx Screwdriver, remove the 5mm screws in the four corners of the motherboard.
Één andere persoon heeft deze handleiding voltooid.
