Wat je nodig hebt
Use the prying tool to release the platic clips on the back, going around all the sides.
Start prying from the sides or the top left corner and work your way around the screen.
Slide the screen slightly upwards to reveal the connector
Slide up the screen to get access to the connector
Use the plastic prying tool to lift up the latch that secures the ribbon cable and then slide the cable out.
Once the cable is out, lift off the screen.
Before you can take the logic board out disconnect the battery.
Remove the microphone from its socket with a plastic spudger.
Remove the 4 x T5 screws that secures the logic board to the back cover.
Peel off the clear tape from the speaker connections with tweezers.
Use your soldering iron to de-solder the two wires from the speaker.
Finally remove the 4 x T5 screws that secure the logic board to the back cover.
To reveal all the components, use the spudger to lift off the metal cover of the protected circuitry
Repeat the same step on the back of the logic board.
Now you successfully exposed all the parts.
Één andere persoon heeft deze handleiding voltooid.
