Ga door naar hoofdinhoud
Garmin Nuvi 2455LMT Touch Screen Replacement
Wat je nodig hebt
  1. Garmin Nuvi 2455LMT Touch Screen Replacement, Back Panel Assembly: stap 1, afbeelding 1 van 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Touch Screen Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 2455LMT Touch Screen Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Touch Screen Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 2455LMT Touch Screen Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 2455LMT Touch Screen Replacement: stap 3, afbeelding 3 van 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: stap 4, afbeelding 1 van 2 Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: stap 4, afbeelding 2 van 2
    • Locate the edge of the screen that fits into the plastic case
    • To separate the connector, gently push the tip of a spudger under the clip.
    • Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
  5. Garmin Nuvi 2455LMT Touch Screen Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool to wedge between the plastic cover and screen.
    • Using your hands, gently push the front of the screen towards you to push the screen out of the casing.
Conclusie
Torrance Williams
229 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-3, Blackwell Fall 2016 Lid van USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 622
