Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Peel off the sticker in order to find the two Torx T5 screws.
Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
Once you have a little gap, work it around the whole device with the tool to get separation.
Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
Slide the orange ribbon cable away from the ZIF connector.
Using a screw driver, unscrew the four 2mm screws holding the motherboard in place.
Using the black spudger, apply pressure to nudge the plug out of its port.
Repeat this process for both ports.
Using the plastic opening tool, carefully apply pressure to lift the speaker up from the back cover.
Één andere persoon heeft deze handleiding voltooid.
