Ga door naar hoofdinhoud
Inleiding
The back cover to the Garmin Nuvi 200W is exposed more than other internal elements of the device. Due to this vulnerable position, the cover may become scratched, damaged, or broken under stress. Replacing the rear cover can make the Nuvi 200W look new again, at much less cost!
It is important to note, however, that the case and it's internals require very specific screws, that are small and easy to lose. It is recommended that a magnet or tap is used to secure screws after removal. It is also important to gently remove the back cover, as it will be attached to other interior elements. This connection is sensitive and should be treated as such until the guide shows proper disconnection of this particular cable.
Only basic tools are required, such as screw drivers, and opening tools.
Onderdelen
Geen onderdelen opgegeven.
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: stap 1, afbeelding 1 van 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: stap 1, afbeelding 2 van 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: stap 1, afbeelding 3 van 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: stap 3, afbeelding 1 van 3 Garmin Nuvi 200W  Rear Cover Replacement: stap 3, afbeelding 2 van 3 Garmin Nuvi 200W  Rear Cover Replacement: stap 3, afbeelding 3 van 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: stap 4, afbeelding 1 van 2 Garmin Nuvi 200W  Rear Cover Replacement: stap 4, afbeelding 2 van 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
Conclusie
Matthew Eires
319 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 178
