Ga door naar hoofdinhoud
Garmin Nuvi 1490T Speaker Replacement
Wat je nodig hebt
  1. Garmin Nuvi 1490T Speaker Replacement, Front Frame Panel: stap 1, afbeelding 1 van 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Speaker Replacement: stap 2, afbeelding 1 van 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Speaker Replacement: stap 3, afbeelding 1 van 2 Garmin Nuvi 1490T Speaker Replacement: stap 3, afbeelding 2 van 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: stap 4, afbeelding 1 van 3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: stap 4, afbeelding 2 van 3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: stap 4, afbeelding 3 van 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Speaker Replacement: stap 5, afbeelding 1 van 3 Garmin Nuvi 1490T Speaker Replacement: stap 5, afbeelding 2 van 3 Garmin Nuvi 1490T Speaker Replacement: stap 5, afbeelding 3 van 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Garmin Nuvi 1490T Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
  7. Garmin Nuvi 1490T Speaker Replacement: stap 7, afbeelding 1 van 2 Garmin Nuvi 1490T Speaker Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, gently clamp onto the white plastic end of the speaker connector.
    • Remove it by pulling slightly towards the speaker.
  8. Garmin Nuvi 1490T Speaker Replacement: stap 8, afbeelding 1 van 3 Garmin Nuvi 1490T Speaker Replacement: stap 8, afbeelding 2 van 3 Garmin Nuvi 1490T Speaker Replacement: stap 8, afbeelding 3 van 3
    • Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Slide the tool around the perimeter to fully dislodge the speaker.
Conclusie
Ricardo Solis
1.037 Reputatie
6 handleidingen geschreven
USF Tampa, Team 15-2, Remmell Spring 2016 Lid van USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 253
