Ga door naar hoofdinhoud
Garmin Nuvi 1390LMT Battery Replacement
Wat je nodig hebt
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: stap 2, afbeelding 1 van 2 Garmin Nuvi 1390LMT Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: stap 3, afbeelding 1 van 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: stap 4, afbeelding 1 van 2 Garmin Nuvi 1390LMT Battery Replacement: stap 4, afbeelding 2 van 2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: stap 6, afbeelding 1 van 2 Garmin Nuvi 1390LMT Battery Replacement: stap 6, afbeelding 2 van 2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: stap 8, afbeelding 1 van 2 Garmin Nuvi 1390LMT Battery Replacement: stap 8, afbeelding 2 van 2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Trey Ulsh
537 Reputatie
3 handleidingen geschreven
Montana Tech, Team 10-4, Shirk Fall 2015 Lid van Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 Leden
Één opmerking
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 3,766
