Ga door naar hoofdinhoud
Garmin Nüvi 52LM Battery Replacement
Wat je nodig hebt
  1. Garmin Nüvi 52LM Battery Replacement, Garmin Nüvi 52LM Disassembly: stap 1, afbeelding 1 van 2 Garmin Nüvi 52LM Battery Replacement, Garmin Nüvi 52LM Disassembly: stap 1, afbeelding 2 van 2
    • Place the device face-down, with the screen facing the surface. There are 8.7mm screws located in each of the back 4 corners of the device. Using a T5 Torx screw bit, unscrew all four screws and leave them aside.
  2. Garmin Nüvi 52LM Battery Replacement: stap 2, afbeelding 1 van 2 Garmin Nüvi 52LM Battery Replacement: stap 2, afbeelding 2 van 2
    • Place a plastic opening tool in the seam between the back and front plates of the device. Using constant pressure, slowly and continuously slide the tool along the seam. The tool should disable each of the hooks holding the two plates together. If unsuccessful, apply slightly more pressure and try again.
    • Once all hooks are disabled, slowly separate the two plates, being careful not to damage the ribbon wire still connecting the two.
  3. Garmin Nüvi 52LM Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Garmin Nüvi 52LM Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Using the T5 Torx screwdriver, unscrew the two 5.6mm screws at the top right and bottom right corners of the motherboard.
  4. Garmin Nüvi 52LM Battery Replacement: stap 4, afbeelding 1 van 2 Garmin Nüvi 52LM Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently unplug the wire connecting the battery to the small socket on the back of the motherboard.
  5. Garmin Nüvi 52LM Battery Replacement: stap 5, afbeelding 1 van 2 Garmin Nüvi 52LM Battery Replacement: stap 5, afbeelding 2 van 2
    • Using a plastic opening tool, pry the battery from the back cover of the device. There may be an adhesive sticker keeping it in place, so you may need to apply some force.
    • The battery should now be completely detached from the other parts.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Camron Dennler
146 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-1, Banghart Winter 2017 Lid van Cal Poly, Team 10-1, Banghart Winter 2017
CPSU-BANGHART-W17S10G1
4 Leden
5 handleidingen geschreven
Één opmerking
I was told the small connector at the back of my device is the problem. I am thinking it may be the battery. I don’t really want to throw my gps away if I can fix it! Thanks!
gsolomon77 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 2,274
