Inleiding
In this guide the repairer replaces the speaker of the device by disassembling the device further to expose the motherboard and speaker.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
Onderdelen
Geen onderdelen nodig.
  1. After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. The motherboard will now freely separate from the back casing; lay it flat next to the housing. The motherboard will now freely separate from the back casing; lay it flat next to the housing.
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  5. Detach blue speaker cable from motherboard. Battery cable is detached in this picture, and it is not required to do so to install a new speaker. Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
    • Detach blue speaker cable from motherboard.
      • Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
  6. Detach speaker from casing and insert new, functional speaker. Battery is removed in the picture and is not required for the installation of a new speaker.
    • Detach speaker from casing and insert new, functional speaker.
      • Battery is removed in the picture and is not required for the installation of a new speaker.
Conclusie
Matt West
22 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-65, Johann Spring 2013 Lid van Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 3
Altijd: 253
