Ga door naar hoofdinhoud
Garmin GPSmap 60CSx Screen Replacement
Wat je nodig hebt
  1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: stap 1, afbeelding 1 van 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Screen Replacement: stap 2, afbeelding 1 van 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Screen Replacement: stap 3, afbeelding 1 van 2 Garmin GPSmap 60CSx Screen Replacement: stap 3, afbeelding 2 van 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Screen Replacement, Screen: stap 4, afbeelding 1 van 2 Garmin GPSmap 60CSx Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Screen Replacement: stap 5, afbeelding 1 van 1
    • Take the spudger and place it in the bottom right corner of the black PCB cover.
    • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
    • It is best to do remove the bottom corners first.
    • Pull the PCB cover out of the GPSMap 60CSx.
  6. Garmin GPSmap 60CSx Screen Replacement: stap 6, afbeelding 1 van 2 Garmin GPSmap 60CSx Screen Replacement: stap 6, afbeelding 2 van 2
    • Carefully use the spudger to lift the PCB a few centimeters.
    • Pull the PCB towards the bottom of the GPSMap 60CSx.
    • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
  7. Garmin GPSmap 60CSx Screen Replacement: stap 7, afbeelding 1 van 3 Garmin GPSmap 60CSx Screen Replacement: stap 7, afbeelding 2 van 3 Garmin GPSmap 60CSx Screen Replacement: stap 7, afbeelding 3 van 3
    • Apply light pressure to the four white tabs that are holding the screen in place.
    • The screen will now come off the PCB.
  8. Garmin GPSmap 60CSx Screen Replacement: stap 8, afbeelding 1 van 1
    • Turn the PCB over so the screen connector is facing you.
    • Move the screen out of the way for access to the screen connector.
  9. Garmin GPSmap 60CSx Screen Replacement: stap 9, afbeelding 1 van 3 Garmin GPSmap 60CSx Screen Replacement: stap 9, afbeelding 2 van 3 Garmin GPSmap 60CSx Screen Replacement: stap 9, afbeelding 3 van 3
    • Use tweezers to pull the two white pins on the connector forward.
  10. Garmin GPSmap 60CSx Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the screen ribbon connector and screen.
Conclusie
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Antwoord
Thank you for these step by step detailed instructions.
jlciscorp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 36
Altijd: 4,584
