Inleiding
If the screen remains blank while the device is turned on, is cracked and unable to be used, or remains unresponsive, the screen may be broken and need to be replaced. The following are steps on how to replace the screen of the Garmin GPSmap 60CSx.
Wat je nodig hebt
Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
Remove the black, yellow, blue, and red wires connected to the PCB with light force.
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
i have a 60csx and the battery bounces the liquid, can help me?
