Ga door naar hoofdinhoud
Garmin Fenix 3 HR Motherboard Replacement
Wat je nodig hebt
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: stap 2, afbeelding 1 van 2 Garmin Fenix 3 HR Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: stap 4, afbeelding 1 van 2 Garmin Fenix 3 HR Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: stap 7, afbeelding 1 van 1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Now attach battery to new motherboard and reassemble.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jacob Smiley
277 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G6, Harley Spring 2018 Lid van IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Leden
4 handleidingen geschreven
2 opmerkingen
And where would one source replacement motherboard?
jonathan.hatchuel - Antwoord
donde puedo encontras placa.madre reeemplazo????
luis zavala - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 26
Altijd: 4,766
