Inleiding
If your GPS is failing to find your location, lags, or performs oddly, you can use this guide to locate and replace the antenna, which is located inside the watch. To do this, you will need a T6 Torx screwdriver and a spudger. Tweezers are best used for extracting the GPS antenna.
Wat je nodig hebt
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Set the watch face aside.
Één andere persoon heeft deze handleiding voltooid.
8 opmerkingen
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
Hi did you find gps antenna
Bonjour, Idem, après plusieurs semaines de recherche pourquoi mon GPS ne fonctionne plus j'ai voulu changer cette pièce mais je ne la trouve pas !
Indeed where can I but a Gps antenna for Fenix 3hr?
Has anyone managed to find a source for a Fenix gps antenna? thanks in advance for any help
